Perfect for those who want to test ecus after repair/remaps possibly directly on bench without the need of an actual engine.
Works on OBD0 and OBD1 ecus!
Power input : 12v dc (needs a 12v 2a power adapter)
RPM : 0 – 12 390
Inputs/ Outputs :
4 injectors
IAT
ECT
TPS
ICM
MIL + switch - to check codes
VTEC function - available as separate module
Module only : 150 usd
Module + box : 200 usd
Module + box + Loom(leads to connect directly to ecu) : 240 usd
Ships from Europe only with tracking number/ i will not post it otherwise (buyer pays postage).
