It is currently Mon Jun 17, 2019 3:04 pm
 Post subject: ECU Debugger
PostPosted: Mon Oct 31, 2005 9:59 pm
I want to know the program flow through the ecu code. I think it would help a TON with code development. Maybe this is a really dumb idea but how could we monitor the program counter?
I thought of using some mechanism in the rom code (serial interrupt or something we could call often) but when it got executed to send me the PC word, it would be the PC word for the serial sending code. Even with a serial interrupt, we would not be getting every instruction executed. And if the ecu was streaming this info, the serial port probably couldnt keep up.
Does anyone have any ideas? I suppose I could take some snapshots of memory (the entire memory space) and go through the program flow like that, but I want the PC data.
Ben
PostPosted: Tue Nov 01, 2005 5:02 pm
Could this be done externally? I remember from my days of using Borland Turbo Pascal and others that they had a step through feature where it would go to the next instruction each time you hit the F8 key (I think). It would also allow you to keep track of Variable values for each step. Of course, implementing this would be taxing, as you'd need to essentially write a 66xxx emulator from scratch. It would definitely be worth it though. It would allow those of us who are not gifted coders to follow everything more easily.
PostPosted: Tue Nov 01, 2005 10:22 pm
We know what each command is... we should be able to create a software application that simulates the processor.
PostPosted: Tue Nov 01, 2005 11:35 pm
Is it possible that Oki already has this? :shock: It would make sense for them to have written it at some point...
PostPosted: Tue Nov 01, 2005 11:42 pm
I don't know S*-t about what you guys are talking but I think that you could use the trace function of the Romulator sotware to see the processor working.
PostPosted: Wed Nov 02, 2005 2:47 pm
:shock: :roll: :lol: Yeah, probably... :D
 Post subject: Re: ECU Debugger
PostPosted: Mon Mar 29, 2010 12:15 am
I know this is an old thread but does anybody have a program that logs address hits from an ostrich? I would write one, but dont really have time at the minute?
PostPosted: Mon Mar 29, 2010 11:40 am
PGMFI Elf
Not publicly, you'd have to write one.
PostPosted: Thu Apr 08, 2010 3:48 pm
was wondering what the hell that trace function was for... :oops:
http://www.moates.net/zips/firmware/protocols/Moates%20Hardware%20Protocols%20v19.zip
if your looking to see if specific sections of code are used, it might be easier to create a datalogging variable and poll that...
PostPosted: Tue Jan 04, 2011 5:36 pm
I've started writing an address tracer for the ostrich V2. it record rom access location within a given range and outputs the code at that rom location from a dasm'd rom.
I'll upload the program once its finished (not long now ;))
More info here -> http://www.hondamod.co.uk/free-stuff/moates-ostrich-v2-rom-tracer
PostPosted: Wed Jan 05, 2011 1:09 am
PGMFI Elf
Neat program!
PostPosted: Wed Jan 05, 2011 1:38 am
ya cant wait till its done
PostPosted: Wed Jan 12, 2011 8:25 pm
man. you guys must be NEO bloodline ... :mrgreen:
PostPosted: Fri Jan 14, 2011 3:28 am
PGMFI Elf
Or common sense and the ability to read directions. It's all documented pretty well. :)
PostPosted: Mon Nov 28, 2011 10:58 pm
Qemu can do it but it would be a shit-ton of work to implement all the virtual hardware.
